IHC 504
Albert Anderson
06-25-2003 11:58:10
Need to find out what the difference in a standard 504 and a HI CLEARAMCE 504 is. Is there a dfiffernce in the side frames. Wanting to mount loader to Hi Clearance and am told that same loader won't fit on both tractors. Can anyone help me on this...
Al Anderson
Hugh MacKay
06-25-2003 16:03:06
 Re: IHC 504 in reply to Albert Anderson, 06-25-2003 11:58:10
Albert: What exactly are you refering to, is it Utility and Farmall. Both Utility and Farmalls have hugh clearence models. If is is the straight Utility and Farmall some loaders will fit both and some will not. You will need model numbers on loaders as well as clarify the tractor for a sound answer.
