W-9, WD-9 weight
26red
07-16-2003 15:03:21
Looking at buying one or the other to restore. How much do they weigh? I have to haul on a trailer or figure a way to tow it about 25 miles.
caseman-d
07-17-2003 20:31:15
 Re: W-9, WD-9 weight in reply to 26red, 07-16-2003 15:03:21
my old wD-9 weighed in at 8500 with 16-34's with chloride and one set of weights. Took the tires off and put them on my W-9 and it weighed closser to 8000. this should give you some ideas. Depends on how far you need to haul it. Double 7000lb axels on a goose neck trailer should handle it great with a 3/4 ton pickup.
caseman-d
Rich
07-16-2003 15:23:31
Depending on weights and fluid it could be up to 12,000 lbs. according to Nebraska test records. Mine has no fluid but four rear wheel weights (it came with 8 weights) so we figure it at 8,000 lbs. I just bought a one-ton truck to feel safer when hauling it.
26Red
07-16-2003 15:30:08
 Re: Re: W-9, WD-9 weight in reply to Rich, 07-16-2003 15:23:31
I guess I better get a bigger trailer! Thanks
meihman
07-17-2003 12:35:16
 Re: Re: Re: W-9, WD-9 weight in reply to 26Red, 07-16-2003 15:30:08
I weighed my wd-9 and with me on it it weighed 8710 lbs. Roughly it weighs 8500 lbs. It has one set of wheel weights. I don't know about the fluid in the tires I just got this tractor and I have not checked that out yet.
