paint job is dull
HANK
07-19-2003 18:14:10
we took a farmall c to bare metal, undercoated,
gave two coats of IH paint with gloss hardner.
Still looks dull.
Any idea what we can do to give a third coat
that will have a decient gloss level?
Jason
07-19-2003 21:05:58
 Re: paint job is dull in reply to HANK, 07-19-2003 18:14:10
By any chance did you have different parts of the tractor near by when painting? I found out that if you would paint, say the hood,get it away from the other stuff you are painting or have the other stuff far away while it drys. The finest amount of over spray going threw the air will land on a good paint job and dull it out while it is trying to dry.
Roger
07-19-2003 19:26:41
Hank, I just painted my Farmall B last week. The first time it was too hot and I got an orange peel finish, so I resanded and this time added more thinner and painted on a cooler day. The second time I got a real nice smooth coat. As some others said, you need to put on just enough paint so it is almost ready to run but not quite. You need to keep it from drying too fast as it will flow for quite a while after painting if you don't have it in the sun or in the wind where it will dry fast. Also, a good spray gun makes a difference. I used to have one of those cheap spray guns and since I bought one of those HVLP guns I have been getting much better results. Roger
here, try this
07-19-2003 18:48:58
in hot weather you might need a slower drying thinner.
dan
07-19-2003 18:17:48
sounds like its dry need to put the pait on heavier its hard to do with out runs good luck
dmp
07-19-2003 19:58:29
 Re: Re: paint job is dull in reply to dan , 07-19-2003 18:17:48
if there is high moisture in the air that wont make a good paint job. paint a thin coat then wait until it is "sticky" then paint your heavier coat.
