new day, same old troubles
here, try this
07-25-2003 19:00:44
560 that I put in a used diferential for a friend this winter seems to be making clunking sounds. I set up the bearings as best I knew how and maybe this is not even the problem. Is there a way to check it out without removing the cover?
Harold Hubbard
07-26-2003 04:30:26
 Re: new day, same old troubles in reply to here, try this, 07-25-2003 19:00:44
Clunking in my 330U turned out to be axle bearings. Two of the balls were broken right in half, when they came around to the right place, CLUNK, sounded sort of like a loose cross chain hitting the fender, did it only in high gear on the road to start with, then got worse. When I jacked it up I could wiggle the wheel up and down with a prybar. The seal on that axle was also leaking.
