starter problem?
d.cushion
07-26-2003 19:15:35
My super C has been starting like a dream for over 6months now.Today I got on her she turned overonce and then nothing.I cleaned cables and connections.Removed starter,removed solenoid and cleaned.Have not taken starter apart yet.what else should I check?
d.Cushion
07-27-2003 14:06:12
 Re: starter problem? in reply to d.cushion, 07-26-2003 19:15:35
Yep I did everything Yall mentioned then I took the starter off .using the old bench test I found that it will bearely turn so its off to the starter shop tommorrow.However as I was fooling with the starter Inoticed a wheel seal leak.At least I know what my next project is.farmalls forever.
Bus Driver
07-27-2003 10:36:41
If the starter is bound against the ring gear, I have found only three things that work to free it. One is to loosen the starter mounting bolts enough to just wiggle the starter- does not even require disconnecting the battery cable. I carry a wrench for this purpose on the tractor- a 140. The other thing is to put the tractor in 4 th gear and push/pull it BACKWARD. The third is to take crowbar and turn the engine backward through the handhole under the clutch. The third one is very inconvenient. If jammed, the hand crank will not turn it nor will pulling it forward in a forward gear. Those things only jam it tighter and do additional damage to the already damaged flywheel ring gear and starter drive.
Jimmy King
07-27-2003 13:48:07
 Re: Re: starter problem? in reply to Bus Driver, 07-27-2003 10:36:41
As I said I don't remember the Super A ever locking but the H was notorious and I have unlocked it 100's of times with the crank.
TomH
07-27-2003 08:12:49
This might be too obvious, but any chance the battery is dead?
Jimmy King
07-26-2003 21:07:45
I don't remember the old Super A doing this but the H was notorious on what we called the starter locked Try putting the tractor in high gear and rock it if this is the problem it will release. Using the crank if you had one also will work. When we used the Super A and H a crank on each was standard equipment.
New Super A Man
07-26-2003 19:43:47
You might try this, I go this info from someone one here when I had this happen to my Super A. If you have not put it back on yet, put it back then try her out. On mine the starter gear binded against the ringgear. (I need to replace the starter drive as soon as I can, that's what caused it) When I removed the starter, obviously it unbinded (i think thats a word) the gears, and when I put it back together, it worked fine. When it happened to me, I tried to start it once, then it did nothing at all. I thought my battery had died as my generator currently is not charging. So tried to jump it off, no change. Came to the forums for advise and got this tip, it worked.
