Farmall M running rough after rebuild
Jeff
07-31-2003 12:47:44
We just rebuilt an old M (rebuild head, new pistons rings etc) and when we started it up, its only hitting on two cylinders. We never took the magneto off and i marked the sparkplug wires so i know they are back on the right plugs. the wires worked fine when we stopped it last. The crankshaft, camshaft, timing gears and magneto were not touched at all. What do you think could be causeing this problem? It runs on #3, and #4 cylinder fine but when you take the wires off of 1 and 2 nothing changes. Could something have happened to the ignition system while it was just sitting there? the engine shows good oil pressure and the valve tappet gaps were set to .020 cold. also the last few times we started it, oil came out of the breather. thanks for any help
jeff
Mark in Mi
08-01-2003 05:11:10
 Re: Farmall M running rough after rebuild in reply to Jeff, 07-31-2003 12:47:44
I agree with Farmer John. Re-adjust your valves. I put a rebuilt head on my brother in laws H and it missed spit and spuddard. Adjusted the valves and it ran fine.
Rick(MN)
07-31-2003 17:52:31
I went thru this very thing a long time ago....fought and fought with it.....couldnt figure it out to save my life.....like you it was 2 cylinders right next to each other....was laying in bed one night and it came to me....the only thing these 2 cylinders had in common was the intake.....jumped out of bed....got dressed and ran out to the shop....pulled the manifold off and found a small peice of rusty gasket material that I had missed when I cleaned the manifold....cleaned it up....put the manifold back on and it ran like a champ...goes thru my mind every time I remove or replace a manifold.....Good Luck...Rick
rustyfarmall
07-31-2003 17:01:24
Try a couple of different spark plugs, sometimes the new ones aren't any good. just a thought.
Van
07-31-2003 15:29:33
Check out the ignition system, possibly fouled plugs from the rebuild lube
MIKE ODONNELL
07-31-2003 16:50:13
 Re: Re: Farmall M running rough after rebuild in reply to Van, 07-31-2003 15:29:33
CHECK YOUR MANIFOLD IT MAY BE CRACKED ON THOSE CYLINDERS. WHEN YOU TOOK IT OFF IT WARPED AND WHEN YOU PUT IT BACK ON IT CRACKED SUCKING AIR AWAY FROM THE CARB. i'LL PUT A MILLION DOLLARS ON TI.
Tractor Dan
07-31-2003 18:14:14
 Re: Re: Re: Farmall M running rough after rebuild in reply to MIKE ODONNELL, 07-31-2003 16:50:13
last i know you were a little short of a million dallars but hows the md doing
MIKE ODONNELL
08-01-2003 11:20:59
 Re: Re: Re: Re: Farmall M running rough after rebu in reply to Tractor Dan, 07-31-2003 18:14:14
RUNNING GREAT GOT A NEW SEAT AND BATTERY BOX GOT THE GAS SYSTEM WORKING ALSO.. MY FREIND IS BRINGING OVER SOME TIRES FOR ME FOR THE REAR THEN i,M GOING TO TAKE IT OUT AND BREAK IT IN REAL GOOD.
Farmer John
07-31-2003 13:10:17
You have probably got the valves adjusted too tight on these cylinders. Tyr re-adjusting the valves to .017 and see if it starts hitting on all 4.
Van
07-31-2003 15:26:21
 Re: Re: Farmall M running rough after rebuild in reply to Farmer John, 07-31-2003 13:10:17
Last time I checked .020 was looser than .017
Andy Martin
07-31-2003 15:59:55
 Re: Re: Re: Farmall M running rough after rebuild in reply to Van, 07-31-2003 15:26:21
Im sure he meant 0.017 hot.
Are you getting fire from No' 1 and 2 wires?
If so, I'd bet on the wire switching gremlin.
Jeff
07-31-2003 17:35:16
 Re: Re: Re: Re: Farmall M running rough after rebu in reply to Andy Martin, 07-31-2003 15:59:55
we tried taking off #3 and #2 plugs and hooking the wires back up to them to see if there was a spark. from what my dad and i could tell when we turned the motor over, the spark looked the same on both plugs. in fact the motor still ran (just barely) when #3 and #4 (the "good" plug wires) were unhooked. we tried resetting the tappet gaps, they all seemed to be ok, the motor was not hot enough to set them at .017 so we used .020 again. we also took the distributor cap off and everything looked ok in there too but to the trained eye something might have really been wrong. this thing sure has me stumped, thanks for all the replies!
jeff
