560D timing
Arloff
08-04-2003 18:41:31
What would be the way to re-time a 560D that is 180 out of time? Thanks, Arloff
Chuck
08-04-2003 20:34:17
 Re: 560D timing in reply to Arloff, 08-04-2003 18:41:31
Take the timing window loose on the side of the pump.Turn the engine in direction of rotation by hand until marks line up in the window.Pull the pump off. Turn the engine by hand with the pump off until timing mark lines up, making sure you are on the right cylinder. Reinstall the pump,using new seals to prevent hassles with leaks.I really strongly suggest getting a service manual,if not the IH one at least an I&T one.They are much less expensive and have a lot of good information in them.They are also sold at farm supply stores so they are easy to get. There's my 2 cents worth.
