Farmall MD (hydralics pump seal)?
Super Dave
08-05-2003 20:06:40
Hey there guys: I was wondering if any body can tell me how to get the seal (round seal) off the hydralics pump I took the pump out and apart BUT I cant seem to get get one of gears the off, the one has the key in it can any body tell me how to remove that shaft so I can take the seal out?? Thanks for yours guys help in Advance Super Dave in MN
Haas
08-07-2003 06:06:08
 Re: Farmall MD (hydralics pump seal)? in reply to Super Dave, 08-05-2003 20:06:40
You don't have to take the gear off the shaft to replace the seal. The coupling piece comes off the shaft by unscrewing it counter clockwise. They get locked on real tight because the power to the pump screws them on tighter. Once you get the coupling piece off, if you have the pump apart, the shaft and gear piece will slide out and you can replace the seal easily. To unscrew the coupling piece, I made a wood clamp out of oak that would fit the gear, clamped the gear in a vise and then used a square bar in the coupling slot to unscrew the coupling half. It took several sharp raps on the bar with a hammer to free up the coupling.
Sam#3
08-05-2003 21:58:51
I had the same problem just last week on my Case.
I took it to a machine shop with a gear press. I'm thinking it may have be pressed back also.
