Do I need a triplet knife?
John
08-09-2003 14:55:19
Gang,
I broke the end knife blade on my Cub LoBoy's L22 sickle bar mower a few weeks ago. This is a triplet knife. Can't find triplet knife blades anywhere, but can get a universal doublet.
I'm told the triplet is used to avoid clogging the end of the mower. Can I use a doublet in it's place, or should I go to the trouble of welding my triplet back together, grinding it to finish, and re-riveting it onto the knife bar?
Any advice is appreciated.
Thanks
John
Dave_Id
08-09-2003 15:37:16
 Re: Do I need a triplet knife? in reply to John, 08-09-2003 14:55:19
The sickle bar on my swather has a half section right at the end, flat to the outside to keep it clean. Perhaps you can install a normal section and one of those half ones that you can buy at the Ih store, or perhaps any tractor store..
Bob McCammon
08-09-2003 17:52:00
 Re: Re: Do I need a triplet knife? in reply to Dave_Id, 08-09-2003 15:37:16
The will fit section was a double one. The IH made one was a triple. Either will work.
