560 steering troubles
Harley
08-18-2003 20:53:44
Hi,
I work on my aunts farm here in PA. She rents the ground out to another farmer, but I still need to do some basic maintainence here and there. I have to use the 560 to do almost everything.
I've had problems with the engine not running well, and I fixed all the major problems. However beginning in the spring, the steering becomes very stiff. It had water in the trans, so I changed the fluid thinking that was them problem. It didn't help. The steering seems like it loses power now and then, and then for seemingly no reason, it'll steer with no trouble at all. I don't really mind except for when I have to back up.
It's a gas engine and a tricycle front. I was wondering if anybody here has any ideas about what the problem might be.
Thank you.
Harley
Nebraska Cowman
08-19-2003 03:52:21
 Re: 560 steering troubles in reply to Harley, 08-18-2003 20:53:44
did you change the hydralic filter and clean the screen? it is under a flat plate on the side of the transmission.
Harley
08-20-2003 18:31:09
 Re: Re: 560 steering troubles in reply to Nebraska Cowman, 08-19-2003 03:52:21
I got it when I changed the oil.
Thanks
