points and magneto
pete
08-20-2003 18:56:28
were are the points located in the mag on my 1940 farmall a
gene b
08-21-2003 03:12:25
 Re: points and magneto in reply to pete, 08-20-2003 18:56:28
You better be careful when you take it apart so you get the front cover back on and not get the rotor out of time. If it has fire leave it alone. I have tractors that havent had them changed in many years and they perform excellent.
Vern
08-20-2003 21:30:19
After you remove the dist. cap and rotor there is a plate with screws in it. remove these screws, remove the plate and you will find the points.
