SUPER A COIL GETTING HOT/TRACTOR WILL NOT RUN
Jon in OH
08-25-2003 15:32:46
CAN NOT GET SUPER A TO RUN RIGHT.HAS ABAD MISSAND WILL NOT HARDLY RUN THE COIL GETS SO HOT CAN NOT TOUCH.WILL A BAD COIL CAUSE PROBLEM .THIS IS A 6 VOLT .HAVE REPLACED EVERYTHING ELES.POINTS,CAP,WIRES,PLUGS AND HAVE REBUILT CARB .I NEED HELP ?????
Hugh MacKay
08-25-2003 20:26:47
 Re: SUPER A COIL GETTING HOT/TRACTOR WILL NOT RUN in reply to Jon in OH, 08-25-2003 15:32:46
Jon: You didn't say but if the tractor runs fine when first started or cold and gets worse a it warms up then by all means I would look to the coil for problem.
Andy Martin
08-25-2003 15:54:10
A bad coil can act as you describe.
