Cheap HP on an H
Digger
09-02-2003 14:30:24
I farmall H, I bought 3 to 4 mounths ago. I've already repaced the carb with Super H carb.I'm runnig Bosch plugs and still run out of power in the 4500lb. class. Is there a simple less expecive rought than over bore and strokeing it?
tom
09-03-2003 04:15:14
 Re: Cheap HP on an H in reply to Digger, 09-02-2003 14:30:24
IH made a LP H engine, i have a U4 power unit that is LP
MPJ
09-02-2003 17:19:54
Get smaller tires it will reduce your final drive ratio. A K&N air filter helps (Most large auto parts chains will order one for you.)
Doug in OR
09-02-2003 16:31:47
The H/SH carbs are the same, I believe. The plugs will get you little or nothing, unless the old ones were worn. An LP manifold (did they make an LP H? I don't even think so) would get you maybe a couple HP. If you have a distillate head and switch to a gasoline head, you will gain a couple HP. Milling the head will help, but is not recommended on this engine. In a nutshell, it is hard to get much more HP from this engine without going to more cubes and higher compression pistons.
supermpuller4
09-02-2003 17:12:14
 Re: Re: Cheap HP on an H in reply to Doug in OR, 09-02-2003 16:31:47
The carb on a SH are bigger, the lp parts come off a 350
supermpuller4
09-02-2003 14:43:43
LP parts and more rpm's
digger
09-02-2003 15:04:50
 Re: Re: Cheap HP on an H in reply to supermpuller4, 09-02-2003 14:43:43
How do you get more rpm with the gover working against you
stuart martin
09-02-2003 19:34:47
 Re: Re: Re: Cheap HP on an H in reply to digger, 09-02-2003 15:04:50
you can wire the gover open and it will really scream. i pull a super m with a 450 motor and M&W piston kit in it and i just wire it open and I WIN in the 6500 and 7000 lbs class. Ijust hope your motor is nice and tight. make sure to hang on
ken c
09-02-2003 15:14:44
How much compression do you have? which head type do you have (distalate or gas)? I have a 1945 H I changed the head from distalate to gas and it has the low gear I just got a second pulling dead weight in the 5500# class and only run about half throttle. carb. and timing adjustment can make a lot of difference also . E mail me if I can help I will be glad too.
digger
09-02-2003 20:01:24
 Re: Re: Re: Re: Cheap HP on an H in reply to ken c, 09-02-2003 15:14:44
I didn't get your email ken mine is digger_974@yahoo.com I also have aquired a head from 300 to try to incress compression. my for each pistion is 115psi + or - 1 to 2 psi. Thanks for the help.
