300 HP question
Kelly C
09-12-2003 20:36:20
If I order the 3 5/8 step head piston kit for my 300. What would the avg HP be for the tractor?
kennebunksawmill
03-07-2009 09:06:00
 charging question in reply to
wijim
03-07-2009 11:17:42
 Re: Fast hitch plow in reply to Mark W., 03-06-2009 09:33:22
can you post a pic, I have a 211 and my plow shares have part of the landside on them. thanks jim
Nebraska Cowman
12-31-2009 07:41:50
 Re: Farmall regular main bearing play in reply to ScottyHOMEy, 12-30-2009 18:47:32
The only thing I can find is in an old "Motors" manual. It states, "If the play seems excessive in either direction the bearings must be renewed" I'm guessing that with that much play it would knock under load. Just to run slow with no load you might get away with it.
Hugh MacKay
09-13-2003 18:18:18
 Re: 300 HP question in reply to Kelly C, 09-12-2003 20:36:20
Kelly: There was not too much wrong with original equipment on 300's. Most of them 43 years ago were turning out 10% more hp than IH or Nebraska listed them. I have seen a good number of them make 45 hp on a dyno. I think that had a bit to do with them being heavy drinkers.
justin
09-13-2003 07:38:53
Depends on who the maker of the kit is. As far as aftermarket, they are all different. IH Firecraters and M&W mirror each other when compared with the standard altitude, but considering IH wouldn't rate the High altitude at STD altitude for reliability and other reasons, no comparison from company lit can be made.
Roy in UK
09-13-2003 05:24:01
You had me scared there for a minute Kelly, I thought you were looking for a 300h.p. tractor for your NH 68 baler!
