Farmall A Cultivator help!!!!
Mark
10-05-2003 11:30:50
I recently aquired two sets of cultivators for Farmall A's. However, I have never seen a complete mounted set. Anybody have a diagram or a good photo of a mounted set you could email me?
Thanks
Mark
gene b
10-06-2003 19:28:59
 Re: Farmall A Cultivator help!!!! in reply to Mark, 10-05-2003 11:30:50
There is th A-136 and the A-138 also the A-435 veggie set up. Does yours have the pipe frame or the rect one also manual lift or exhaust. You need the operaters manual it shows all the different types of tooling. I have several ones but not the pipe frame one. Try and find the manual it will answer all your questions.
Fm.
10-05-2003 15:00:24
Not sure if it'll help, but below is a link to a photo of my A with cultivators. It isn't that complicated....the lever mounts to the left of the shifter, the rockshaft to the torque tube, and the front of the cultivators go into the square holes behind the front axle, by the steering box. If you have track erasers I don't have a clue--although I wish I did I don't.
Mike
Guy Fay
10-05-2003 14:12:17
Binder Books might sell these, otherwise you can get photocopies from the Wisconsin Historical Society.
Paul in Mich
10-05-2003 11:52:23
I saw a source for a manual for the "A" cultivator, but for the life of me, I cant remember where. I just know they exist. if you find one, fill us in. Where are you located? I may eventually be in the market for a set if you have one set too many.
Mark
10-05-2003 12:36:45
 Re: Re: Farmall A Cultivator help!!!! in reply to Paul in Mich, 10-05-2003 11:52:23
I only need one set, if you are interested in the other set. I am near Syracuse, NY.
