SUPER A STILL NOT RUNNING
BILL IN VT
10-14-2003 03:25:41
I AM STILL NOT ABLE TO START MY SUPER A. IT WAS RUNNING BEAUTIFULLY,, THEN STOPPED DEAD. I have cleaned the fuel line, screen and sediment bowl. There seems to be good fuel flow. I checked for spark by looking at the points and cranking, but there was no visible spark. I changed out the condenser, still no turning over. Any other ideas?? Up to Sunday afternoon this tractor ran like a top!
Steve
10-14-2003 22:24:28
 Re: SUPER A STILL NOT RUNNING in reply to BILL IN VT, 10-14-2003 03:25:41
Bill, all of the information you have recieved is exactly dead on. But do me a favor do you own a volt meter ? if so turn the ignition on and check for fire at the coil the wire runs from the ignition switch down the side of the tranny and engine and so is suseptable to heat if you have voltage there the do this one small thing open the points Gently and take one of your wifes emory boards and just rough up the points a little dont file too much you just want to clean em up also look and see if there is any contact left ( if not it will look like two pieces of straight metal instead of small round contacts) the reason i say this is I bought a 140 and i had to do this same thing to get it started points are bad to just loose contact and not conduct the spark and they will do this going down the field or the road i always carried a piece of sand paper or emory board in my old trucks LOL
try this it just might get you going again. Oh one more thing take the rotor off look at the silver blade on top is there a small burn on the top and under the bottom of the blade if so its the rotor button
HI Hugh
bill in vt
10-15-2003 03:17:29
 Re: Re: SUPER A STILL NOT RUNNING in reply to Steve, 10-14-2003 22:24:28
Steve,
Thanks. Where do I hook up the voltmeter? What are the hook-up points on the ignition switch side? at the cut-off switch or at the terminals?? Do I disconect the wire from the coil? or distributor and hook up there? There appeared to be a small burn on the rotor blade, but it was only a very small dot, the silver button itself looked ok. I think the timing might be off. I am going to try all the other stuff that Gary suggested as well.
Dave, Sherburne, NY
10-14-2003 16:31:58
I had the same problem last weekend just before
the tractor pull. Tractor died and wouldn't start.
First thing I did was pull the coil wire out of the Distributor cap and hold it near the block
while I turned the engine over. NO SPARK
Took of the cap, rotor, and plastic cover. With the switch on, I opened and closed the points by hand YES SPARK at the coil wire. Reassembled the dist, and my grandaughter placed 4th in the 3750lb. class. Apparently something got between the points.
bob s
10-14-2003 13:02:06
bill
send me and e mail. i am in vermont.may be not to far away.could come out and take a look?
KURT (mi)
10-14-2003 08:38:56
you may have tried this but make sure the distrubutor shaft is turning.
Gary_N_WV
10-14-2003 07:54:50
Bill, I ran into this page and thought that maybe it might help you understand a little about your ignition system.....(assuming that it isn't a mag).
Although the "working diagram" isn't exactly what you have, it gives you a good idea of what is happening. The diagram shows an electronic sensor instead of points, but if you read through this there is a description of mechanical points on another page.
I just thought it might help you or someone else to understand what and how an ignition works.
Gary
Gary_N_WV
10-14-2003 05:32:34
I don't know anything about mags, but if you have a coil distributor..... ....
Did you check to see if you are getting "fire" from your coil?
Take the end of the coil wire that plugs into the distributor cap and hold it about a 1/16 inch away from metal on the engine block and then crank the engine to see if you get spark.
There are a lot of very knowledgeable people on this forum, if you post back with results you get from all the suggestions, they will soon have you "running"
Good luck !
bill in vt
10-14-2003 06:39:11
 Re: Re: SUPER A STILL NOT RUNNING in reply to Gary_N_WV, 10-14-2003 05:32:34
I didn't see any spark at the points. Is it safe to check for "fire" from the coil, if there is oil and grease on the engine block. Wouldn't want to scare the neighbors! And do I need insulated gloves or any special technique to do this test as far as safety goes??
Gary_N_WV
10-14-2003 06:48:57
 Re: Re: Re: SUPER A STILL NOT RUNNING in reply to bill in vt, 10-14-2003 06:39:11
I wouldn't worry too much about oil and grease, but gas is a different story..... make sure you don't have any spilled on the side of the engine etc.
Your distributor is on the opposite side of the carb, so gas shouldn't be a problem.
And....don't do it inside a garage ....just to be safe.
If you hold the wire by the rubber insulation on the wire, you will be OK.....just don't hold the end where the little metal clip is.
(I might mention that if you have a Heart Pace-maker, maybe it isn't a good idea to fool with this)
Use common sense anytime you are working with stuff like this.
bill in vt
10-14-2003 09:40:51
 Re: Re: Re: Re: SUPER A STILL NOT RUNNING in reply to Gary_N_WV, 10-14-2003 06:48:57
Thanks to everyone for your suggestions. I am not running yet. I have a coil ignition system, I cranked the engine and did not see spark at the points. I have not done the spark test yet with the ignition coil wire. But what if there is no spark, what next? Also, how do I verify the distributor shaft is turning, do I take it out and crank? Will I mess up anything? (timing, etc??) What if there IS spark at the coil wire? What does no spark at the points mean?? Thanks again
Gary_N_WV
10-14-2003 11:14:15
 Re: Re: Re: Re: Re: SUPER A STILL NOT RUNNING in reply to bill in vt, 10-14-2003 09:40:51
Bill,
I'm going to bore you to death ! ...smile....
Hope some of this will help !
If you have cleaned and checked all the fuel filters and are sure that you have fuel to the carburetor then take a look at the ignition system.
If it tries to start (fires some) when you crank the engine, then you probably have one of several problems…….Fuel system, weak coil, points not set right, bad condenser, bad spark plug wires to name a few.
If it doesn’t even try to start, this should eliminate your spark plugs and spark plug wires.
Pull the coil wire out of the distributor cap and hold it close to the engine block (bare metal) and see if you have spark when you crank the engine over.
If you have spark, then the trouble might be corroded terminals in the distributor, bad rotor button, cracked distributor cap, moisture in the cap just to name a few.
Since your engine was running fine before and suddenly stopped, it probably isn’t moisture or corroded terminals.
If you don’t have any spark from the coil wire, then look to see if your points are opening or closing.
The points have to open and close in order for the coil to spark.
Take the distributor cap off and watch the points while someone cranks the engine.
Another note about the coil…….even though you might have spark, the spark needs to be a blueish-white and not yellow.
Now….lets assume that your points are opening and closing, but you still can’t get a spark from your coil. The next thing you need to do is check to make sure you are getting juice(voltage) from the ignition switch to the coil.
To check this, you can get a piece of wire long enough to connect from the ungrounded side of your battery to the terminal on the coil (not the terminal that has a wire that goes to the distributor, but the other terminal.
Now crank your engine to see if it will fire.
If it fires, it is either your ignition switch or the wiring associated with this.
Another note about the points……….normally, you will see a little spark when you crank the engine but it wont be a large spark.
If you get a large sparking of the points, then your condenser might be the problem.
Without going into great detail ….the coil produces a spark by the collapse of a magnetic field. The condenser is sort of an electric shock absorber that prevents the full spark from jumping back across the points when they open.
If you see a “pretty healthy” spark across the point gap and no spark from the coil, then your condenser might be the problem.
The reason that it is important to see a small spark on the points (assuming coil and wiring is good) is that if the condenser is “shorted”, then it basically eliminates the points and they can’t do their job. (kinda like wiring around the wall switch in your home, the light burns all the time, so the wall switch is useless…..in the case of ignition points, the coil fires at the second the switch is turned off and not when it is turned on.)
Actually, the ignition system on one of these old tractors is pretty simple once you understand how everything is put together and how it operates.
If you have spark from your coil and spark at the ends of your plug wires….and you know it is getting fuel, then the next step is to start looking at the timing of the spark.
The main thing to keep in mind is to eliminate possible problems systematically.
Gary
bill in vt
10-14-2003 17:18:20
 Re: Re: Re: Re: Re: Re: SUPER A STILL NOT RUNNING in reply to Gary_N_WV, 10-14-2003 11:14:15
Gary,
I really appreciate the time you have taken to answer. I have a couple more questions then I hope to get this resolved! Assuming it is the ignition switch, would that be enough to stop a running engine? Checking the spark at the end of a plug, do I remove any spark plug and hold the firing tip near the engine block (similar to holding the coil wire?). What guage wire should I use to jump the ignition switch with? , if it comes to that. If the rotor is not turning then I assume the distributor shaft gear is stripped and I'll need a new distributor. I have the owners manual so I should be able to set the timing if necessary. On Sunday, when it did quit I checked the points and did not see a spark at that time. I'll let you know how it turns out, hopefully soon! Thanks again.
Gary_N_WV
10-14-2003 19:14:01
 Re: Re: Re: Re: Re: Re: Re: SUPER A STILL NOT RUNN in reply to bill in vt, 10-14-2003 17:18:20
Bill, When checking a plug wire to see if you are getting spark, you really don't have to take the plug out, just take the wire off of the plug and hold it near the block. Any wire is OK, but if you don't get a spark, put that wire back on and take another off and try again.....just to eliminate the chance that the first wire is bad.
I don't know the exact amperage a coil draws but I think in the neighborhood of 4 amps. A 14 or 16 gauge wire should work.
My guess is that it's not likely that your ignition switch went bad while you were mowing, but maybe a wire is broken somewhere under the covering, so by jumping around it all you can determine a little better where your problem is.
As for your timing gears being stripped, that is totally possible, but a little less likely than a bad coil or a broken wire etc.....but it can and does happen. Points can get dirt between them or a small wire can come loose in distributors or a dozen other things can happen.
Bill, there are a lot of great guys/gals on this board and 99.9 percent of them are here to help. A lot of different things can go wrong and the combined group of guys and gals have experienced them all.
Some guys/gals have good knowledge of one subject, some have others, and some like Hugh McKay are well seasoned in many subjects.
We are all here to help if we can.
Stick with it, and we'll have you back mowing in no time and you will have some experience that you can pass on to others.
By all means, when you do finally track down the exact problem and cure, get back on here and let everyone know.....
I'll be out of town for a couple of days and not on here to see how you are getting along, but I'll be anxious to get back to see how you fare.
By the way Bill, in what part of Vt. are you located? I've traveled Vermont a little.
Good luck !
Gary
bill in vt
10-15-2003 03:11:02
 Re: Re: Re: Re: Re: Re: Re: Re: SUPER A STILL NOT in reply to Gary_N_WV, 10-14-2003 19:14:01
Gary,
I am armed with lots of info now thanks to you and a few others, just gotta get some time in my sched to go out there and try it all. I am in the Waterford area of VT (probably not on a map)what they call the Northeast Kingdom. Retired out of the service 3 years ago, after 22 years. Got a little place on a hillside, have another tractor as well a Farmall A (1946). I think I can fumble around now without hurting myself or the tractor, worse that could happen is I have to replace a few parts (on the tractor I hope). I'll post back with results.
Gary_N_WV
10-14-2003 10:11:54
Bill, If you do the coil spark test, and have a spark, then it proves that your coil isn't bad....or at least it is working part way.
If the spark from the coil is yellow, then the coil might still be your problem.
If the spark is blue, then your coil is probably OK.
If you do not have a spark, then it could be several things.....no power from the ignition switch, points not opening, bad coil etc.
To tell if your distributor shaft is turning, take the distributor cap off and crank the engine.....you should see the rotor button turning round and round.
After you ensure the rotor is turning,
then you can do a spark test on one of the plug wires."Put your dist cap back on"
Even though you have coil spark, if for some reason the rotor button isn't in the right position when the coil fires your spark won't be routed to the plug wire at the proper time.
If you have a problem with a stripped gear as someone suggested, then things might be out of time enough that you won't get spark to the plug wire at the proper time.
It's sorta like shooting tin cans off the ole board fence, if your gun is pointing somewhere in between the cans, you won't hit one of them.
If your rotor button isn't making contact with the terminal inside your rotor cap to route the spark out the plug wire, your plug won't fire.This could happen if you had a stripped gear.
While you have your distributor cap off, have someone crank the engine while you look at the points.....make sure they are opening and closing.
Do "not" unbolt and take out the distributor.
Chances are...that since you engine was running fine before, that there isn't a major problem..... .
Hugh MacKay
10-14-2003 03:58:17
Bill: I looked at your other thread, have couple of questions. Is the distributor shaft loose? I may have missed something, are you sure distributor shaft is indeed turning? I had a similar experience years ago, and the small gears that drive the distributor between it and the timing gears had striped. Tractor stopped dead in it's tracks.
On the loose distributor shaft, tractor would stop if it hit a bump or received a jolt from a number of sources. On this however I found it would usually restart. Sometines hard to start.
I haven't followed this close enough to see what you checked out. Just giving you a couple of my experiences.
VAJerry
10-14-2003 03:52:49
Mag or coil?
bill in vt
10-14-2003 09:38:52
 Re: Re: SUPER A STILL NOT RUNNING in reply to VAJerry, 10-14-2003 03:52:49
Hugh MacKay
10-14-2003 13:04:43
 Re: Re: Re: SUPER A STILL NOT RUNNING in reply to bill in vt, 10-14-2003 09:38:52
Bill: If you want to check to see if distributor is turning, just remove the cap and turn the crank, to see if rotor turns. Or you could just try and turn the rotor, don't turn to hard you may break it.
The other item that can happen with the small gears that drive the distributor, as the gears get worn they may slip a 1/4 turn on each other, thus throwing your timing off. I have seen this happen. You still should have fire at the coil and points if that is the case.
