Farmall B or BN
Jim
10-15-2003 17:57:54
I've just started restoring a 1941 Farmall B...I think...it's serial number is FAB 43891...it's been in my family since it was new. The confusing thing is, the back end seems narrow like a BN...I haven't measured it, but there is no space between the seat and the left fender...any clues?
JR
Guy Fay
10-16-2003 00:00:40
 Re: Farmall B or BN in reply to Jim, 10-15-2003 17:57:54
BNs in that serial number range did not have the BN prefix. Your serial number should have a X7 stamped after the number or somewhere on the plate. BNs didn't receive the FABN prefix until serial 48350.
Jim
10-16-2003 03:28:46
 Re: Re: Farmall B or BN in reply to Guy Fay, 10-16-2003 00:00:40
The serial number does indeed have the X7...you're saying that means it's a BN? Wonder why the sheet metal has the B decal? I have pictures of my Dad & Uncle on the tractor as boys...it clearly had the B at that point.
When I Restore it, should I put BN decals on?
Guy Fay
10-16-2003 13:30:11
 Re: Re: Re: Farmall B or BN in reply to Jim, 10-16-2003 03:28:46
If it has the X7, it is certainly a BN. I don't know when they started using BN decals- it could have had an early reprint with straight B decals.
Jim
10-16-2003 19:16:20
 Re: Re: Re: Re: Farmall B or BN in reply to Guy Fay, 10-16-2003 13:30:11
Thanks again Guy...a BN it is. I spent some time in your "Letters Series" book tonight looking at the B/BN section. Enjoyed it. We need a spot with good side by side shots of a B and BN:-)
JR
parts man
10-16-2003 18:43:35
Guy's the man! If he don't know no-one does! Sorry about the miss-info. I should have checked my letter series originality guide ( Written by GUY)!! It's a great resource!
Guy Fay
10-16-2003 19:04:20
 Re: Re: Re: Re: Re: Farmall B or BN in reply to parts man, 10-16-2003 18:43:35
Actually, when I went through the letter series book, I was less than happy with the job I did on the BN. This information is from the Data Book I did.
Jim
10-15-2003 18:03:13
My mistake...meant to say no space between the seat and the "right" fender...not the left fender. Also the decals clearly say "B"...not "BN".
parts man
10-15-2003 18:42:33
 Re: Re: Farmall B or BN in reply to Jim, 10-15-2003 18:03:13
Jim, If the ser# says FAB on the seat bracket and engine it is a B that's been modified. The axles would have been changed along with the tube they run in. The way to tell is if there are 4 holes on the top of the axle tube toward the fender where the B seat bracket would mount instead of on the flange at the fender.
Jim
10-16-2003 03:25:30
 Re: Re: Re: Farmall B or BN in reply to parts man, 10-15-2003 18:42:33
Thanks parts man...I'll check it out.
