Farmall 450/NH 850 baler
R. Marg
10-19-2003 12:23:03
will this tractor pull/run a NH 850 large round baler and make full size bales my Oliver 77 will if every thing is just right but how often does that happen Is a 450 big enough or did I shot my self in the foot when I traded my AC 190XT off for the 450 and a celtrac crawler I'd like to know before I set the 450 up to pull it If it isn't I'll just fix up the 450 and trade/sell it for something bigger Thanks for any and all the help
R. Marg
10-19-2003 19:05:17
 Re: Farmall 450/NH 850 baler in reply to R. Marg, 10-19-2003 12:23:03
ok heres a strange question about my 450 I have noticed a sort of round with 2 flat side thing sticking up out of the hood on the right side close to the valve handles might that be what I need to turn I hope it is but I'm not going to touch it till I know or remove the hood to see where it goes unless some one here can tell me thanks for all the help
Ohio Bill
10-20-2003 04:30:01
 Re: Re: Farmall 450/NH 850 baler in reply to R. Marg, 10-19-2003 19:05:17
Not sure what this is. Sounds like a home modification. Remove hood and let us know!
mbnok
10-19-2003 18:31:13
Taking the hood off is a pain. I cut a small hole over the valves and welded a u piece on a rod with a handle so I could change it between single and double action as needed. The little tool lays in the tool box.
mbnok
10-19-2003 13:40:27
I've baled with an 850 NH behind a 400 for 11 or 12 years now. I just open the main jet, new plugs and points each year before starting. Depending on year, bale from 300, to this past year got 550. A 450 should do fine.
R. Marg
10-19-2003 14:58:30
 Re: Re: Farmall 450/NH 850 baler in reply to mbnok, 10-19-2003 13:40:27
can you also tell me how to hook up the Hydrolics just for the heck of it I tried to hook it up today and it would lift it but I had to unhook and rehook to get it to bring it back down I had it hooked up on the right side of the tractor only do I have to hook up 1 on 1 side and the other on the other side???? Thank you for your help
Ohio Bill
10-19-2003 17:34:45
 Re: Re: Re: Farmall 450/NH 850 baler in reply to R. Marg, 10-19-2003 14:58:30
Remove the right engine hood to expose the bank of hydraulic valves. Valves have an index bushing on top that point to "S" or "D." Whatever valve you are running through, be sure "D" is selected for double-action cylinders. Takes a 5/8 wrench, I believe.
R. Marg
10-19-2003 18:31:37
 Re: Re: Re: Re: Farmall 450/NH 850 baler in reply to Ohio Bill, 10-19-2003 17:34:45
Thanks very much I'm good with makeing engines work but since this tractor is new to me and I haven't had the chance to get a manual for it some things are hard to figure out
Brian in MO
10-19-2003 17:23:39
You should have both hoses in the same side, but you may have your valves set for 1-way instead of 2-way. If you move the lever both ways you should hear the hydralics pull down the motor if you don't hear that you need to change the setting on the valve. A manual tells how to do that or post back. Hope this helps Brian.
