47 farmall engine froze need help
bear
10-23-2003 05:46:37
i have a 47 farmall it was running till i got it stuck,1-1/2 years ago.i hooked a chain to the front end and broke the the front end. i found the part for 50 dollars and replaced it.now the engine is froze, i tried to free it by pulling it forward and backwards while popping the clutch, but no luck, it even stoped the truck that was pulling me whe i poped the clutched.seems hard to believe it froze that bad from sitting, can any one give me advice on what to do thanks dave
Tim
10-23-2003 08:58:22
 Re: 47 farmall engine froze need help in reply to bear, 10-23-2003 05:46:37
I seen my dad free up a badly stuck boat motor one time by pouring Pepsi Cola down the cylinders and letting it soak for a few days,came right loose. Something about the acidity of the cola i guess,anybody ever tried this??? Sounds goofy i know,but it does work.
Dave@Id
10-23-2003 07:14:50
You didn't mention what type of Farmall..I wouldn't think a tractor would get stuck that hard in just a year and a half. Is it an A or B?, On those, sometimes the starter drive gets stuck in the forward position and you need to loosen the bolts enough for the starter to reposition itself. Wouldn't that be funny if after you break off the frontend, that it was just the starter?
Allan
10-23-2003 05:59:43
Hi Bear,
You might try pulling the plugs, filling the cylinders with turpentine and letting it set a couple of days. Then try it again.
After it frees up, be sure and change the oil, as that turpentine will work its way down into the pan.
Did you have the exhaust covered while it was parked?
Hope this helps,
Allan
R. Marg
10-23-2003 06:53:52
 Re: Re: 47 farmall engine froze need help in reply to Allan, 10-23-2003 05:59:43
your the first person other then may self that I have ever heard of useing turpentine I know it works well but where did you learn it from just like to know who told you this secret
Allan
10-23-2003 09:11:22
 Re: Re: Re: 47 farmall engine froze need help in reply to R. Marg, 10-23-2003 06:53:52
R Marg,
By accident.
I had an old AC Combine motor stuck one time; and I dooooo mean "stuck". Tried every trick in the book and nothing seemed to work.
Finally in desparation, since I had stumbled across an old gallon can of turpentine that has been setting around the shop for about 10 years, I shook it up and tried it, and the next morning, she came loose (fairly easily).
Surprised me too, 'cause I just never thought there was that much "horsepower" in turpentine.
Allan
R. Marg
10-23-2003 09:34:01
 Re: Re: Re: Re: 47 farmall engine froze need he in reply to Allan, 10-23-2003 09:11:22
an old man told me about it tried it in an AC 190XT that I had traded for the engine was stuck I put the turpentine in it and 2 hours later it was turning over good its also good for rusty tools etc
Nick
10-23-2003 05:56:52
If its that stuck and your pulling it you will bend the rods before it frees up. Try and get a bar in on the flywheel and pry it loose. Be sure to soak it with PB blaster first.
