Retrofitting a Farmall A with hydraulics...
Jesse
10-25-2003 09:42:07
A few weeks ago I noticed a little Farmall A for sale along the roadside that had a hydraulic "box"/tank offset to the front right of the tractor. This box is about 8.5 x 11 and was driven off of the crankshaft pulley. The guy was using it to provide a lift for his mower. I couldn't see any visible markings and the guy wasn't at home to ask, but has anyone seen anything similar and do you know where I can find a tank like this one???
Haas
10-25-2003 10:42:00
 Re: Retrofitting a Farmall A with hydraulics... in reply to Jesse, 10-25-2003 09:42:07
You can mount a small hydraulic pump on the front of the engine and drive it off the generator belt. Northern tool has some little hydraulic pumps designed for belt drive. Then you just need some hoses, a reservoir for the oil and a control valve. Then you will be ready to hook up to a cylinder.
