Inter W4 Split Rims
Lindsay Braddoc
10-29-2003 15:57:01
Can someone tell me how to split the rear rims on an Inter W4 tractor? I have tried with no success. But it appears to me that the outer rim half needs to be removed from the axle spline in order to split it. This does not seem right to me because it would have made changing tyres too difficult to do in the field. Can anyone help?
49 Cubber!
10-30-2003 13:04:09
 Re: Inter W4 Split Rims in reply to Lindsay Braddock, 10-29-2003 15:57:01
Youve lost me.The "rim" is attached to a big heavy hub,which is bolted to the axle with on big bolt.The "rim" is attached to the hub via several clamps on each side of the hub with a bolt.Take out all the bolts and the "rim" comes off,you shouldnt need to take the whole thing off!
Lindsay Braddock
10-30-2003 17:40:30
 Re: Re: Inter W4 Split Rims in reply to 49 Cubber! , 10-30-2003 13:04:09
That's what I would expect. But there are no clamps, just "through" bolts around the rim (about 6 or 8 from memory - sorry, the tractor is 100 miles away - I use it for boat launching off the beach!). Because the wheels have been in salt water, it is not obvious where the rim should split off from the hub. I assume it is at the rim shoulder where it "meets" the hub, but it does not look like a joint to me - perhaps the years of rust and paint layers are disguising it. I have given the rim a tap with the back of an axe to see if it would "break" at the join, but that did not do anything. Maybe I need to try a 15lb sledge hammer????
Nebraska Cowman
10-29-2003 16:14:04
it sounds to me like your rims are mounted backwards with the ring on the inside. Am I correct?
Lindsay Braddock
10-29-2003 19:38:21
 Re: Re: Inter W4 Split Rims in reply to Nebraska Cowman, 10-29-2003 16:14:04
I cannot see how they can be mounted backwards because the inner rims have lifting handles facing outwards.
Nebraska Cowman
10-30-2003 03:21:46
 Re: Re: Re: Inter W4 Split Rims in reply to Lindsay Braddock, 10-29-2003 19:38:21
lifting handles?
please post pictures
Lindsay Braddock
10-30-2003 17:49:06
 Re: Re: Re: Re: Inter W4 Split Rims in reply to Nebraska Cowman, 10-30-2003 03:21:46
Sorry, I cannot post a picture at the moment - the tractor is 100 miles away - I use it for boat launching off the beach.
Yes - two steel handles welded to the rim. Looks like their purpose is to lift the rim off once it splits from the hub. The problem is that I cannot see where the rim spilts from the hub because of years of rust and layers of old paint - looks like the rim and hub are all one piece. And no amount of persuasion with the back of an axe has revealed any sign of a join at the shoulder between the rim and the hub (where it logically should be).
scotc
11-07-2003 21:00:39
 Re: Re: Re: Re: Re: Inter W4 Split Rims in reply to Lindsay Braddock, 10-30-2003 17:49:06
sounds like maybe steel disk wheels, like axle duals. Are the bolts in near the axle or out near the tire?
Lindsay Braddock
11-17-2003 01:30:50
 Re: Re: Re: Re: Re: Re: Inter W4 Split Rims in reply to scotc, 11-07-2003 21:00:39
The bolts are out near the tyre.
