Delco Alternator on a 1955 300 Utility
Mike J.
11-04-2003 10:58:06
I am removing my old generator, and plan to replace it with a standard Chevy Delco alternator. Can you please let me know if this will fit on a 300 utility without modifying the side panels? Fitting it below the side panels make it look like it is going to be a close, close fit. Do you suggest a different type of alternator? Thanks!!
Mike J.
11-05-2003 05:56:17
 Re: Delco Alternator on a 1955 300 Utility in reply to Mike J., 11-04-2003 10:58:06
Thanks for all the help. I really appreciate your input. Since I have already purchased the Delco, I will try to make it work. Again, thanks!!!
D Sellers
11-05-2003 03:25:08
Mike J, I recently installed a delco SI alt. on a 300 utility, was able to use gen bracket, but had to modify slightly, also able to put hood/side panel back in place.It is a tight fit but it will work.D Sellers
mike J.
11-26-2003 09:47:05
 Re: Re: Delco Alternator on a 1955 300 Utility in reply to D Sellers, 11-05-2003 03:25:08
I put a delco on, but my pulley on the alternator is about a 1/4" off from the crank pulley, causing the belt to twist. Do you recommend some type of adjustment or modification?
Dale Kite
11-04-2003 16:31:55
I have had three 300 utilies with Delco alternators and no modification was done.I fits the old generator bracket,the bracket that adjusts the belt tension may have to be bent a little. Find a belt that puts the alternator up close to the valve cover but can be tightened.Most people just take a torch and cut a big hole in the side of the hood you don't have to do that.
BIG JOHN
11-04-2003 14:28:35
I just put up a post about this subject.
Kit Gage
11-04-2003 13:54:27
I asked the same question a while back and a Toyota alternator was suggested to reduce the space problem. I haven't done it yet so I don't know if it is necessary.
Mike J.
11-04-2003 13:59:15
 Re: Re: Delco Alternator on a 1955 300 Utility in reply to Kit Gage, 11-04-2003 13:54:27
Well, I have purchased the Delco, and I am going to give it a try. I sure hope it will works. I will let you know. If anyone else knows, please give me a few pointers. Thanks!!
old
11-04-2003 11:36:12
Don't know if this will help you but my Farmall 450 has one in it and its tight but fits
Mike J.
11-04-2003 14:00:34
 Re: Re: Delco Alternator on a 1955 300 Utility in reply to old, 11-04-2003 11:36:12
Thanks!
