C-113 C123 -- Change out??
JIM
11-20-2003 06:47:53
Hey folks,need a little help!!! Will the C-113 fit in place of the C-123?? If so,are there any draw backs,problems,etc.I got a 100 International,someone let freeze,worse than ever seen,and need a replacement,Thanks!!!
Ken
11-20-2003 14:53:03
 Re: C-113 C123 -- Change out?? in reply to JIM, 11-20-2003 06:47:53
You may have problems with fit. I think the grill and radiator were enlarged.
Dave_Id
11-20-2003 07:04:01
Same engine, just smaller sleeves and pistons. NO problem unless it's from an A or B that didn't have hydraulics.
JIM
11-20-2003 08:39:34
 Re: Re: C-113 C123 -- Change out?? in reply to Dave_Id, 11-20-2003 07:04:01
Thanks Dave!! I will find another C-123,but because of money,at time,want to see smoke!!!
Stan(VA).
11-20-2003 13:00:24
 Re: Re: Re: C-113 C123 -- Change out?? in reply to JIM, 11-20-2003 08:39:34
Jim,
You should be able to use a block out of a C/Super C/200/230/Super A/Super A1/100/130 (not saying they're all the same but you can use them). The C123's in the 140/240 are cast different in the front of the block for the new style water pump and the front pulleys bolt on and use the narrower belt. The C113's in the A/B's would fit but have no hyd pump cutout like was mentioned and you would need a longer bolt and nut for the front bolster where the pump should be.
Stan(VA).
