Steering Gear Housing
Mike
11-23-2003 10:25:54
Have a steering gear housing that leaks. Got to wondering if I could just pack it with grease? This is on a B Farmall. Thanks..
TDK
11-23-2003 23:58:40
 Re: Steering Gear Housing in reply to Mike , 11-23-2003 10:25:54
See your local SNAPPER dealer and ask for SNAPPER"00".See previous post"Grease in steering box"on 11-22-03.Don't forget to replace that seal!
gene b
11-23-2003 18:54:32
Replace the seal then fill with 90wt. The worm and gear will be covered and also the top and bottom ball bearings will get better lube than grease.
BIG JOHN
11-23-2003 10:49:57
I always replace the gear oil in the steering housing with grease. It is almost impossible to keep the seals from leaking gear oil but the grease will stay in the housing and do just fine unless you are in a very, very cold climate which makes the grease get stiff.
GOOD LUCK
