IH 523
smudger
11-24-2003 04:13:26
I have a 523 tractor in my field and would like to
restore it
the only problem is where do you start.
Can,t even get my hands on a manual.
Any help would be great
Klein Rot
11-24-2003 13:04:25
 Re: IH 523 in reply to smudger, 11-24-2003 04:13:26
For manuals and parts books look at
Link
Email egentil@casecorp.com
Klein Rot
11-24-2003 12:58:46
Start with the engine will it start right up is there white smoke a long time, that will point that there is a compression problem, valves or piston rings. Is the engine not greasy, leaking gaskets or oilseals. Than test the clutch is there enough play in the pedal, test the brakes do they work ok. Than the sheet metal. And so you have to work to the end, but grap fist the things that envolve the safety of youself and others (brakes, steering)
Technical information:
engine 3 Cylinder direct injection
max 52 PS(pferde starke) Horse power
r.p.m. 2100
bore 98.4 mm
stroke 128.5 mm
engine displacement 2934 cm3
total wieght 2440 kg
IH Holland
11-24-2003 06:08:59
A 523 starts just like a 423 i own. Next to the contact key is a switch with two positions. Pull the switch in the first position is for the glowing pull the switch further and it starts.
Manuel
11-28-2003 00:37:26
 Re: Re: IH 523 in reply to IH Holland, 11-24-2003 06:08:59
The IH534 was made from 1969-72. Had the D179 German motor. Manuals are still available.
Hope this helps. Manuel
