715,815,915 combine diesel motor options.
Sean W
11-26-2003 20:04:59
What did the 715, 815, and 915 combines have for diesel motors? What are the specs of them motors, such as horsepower, torque, max rpms, etc. Thanks!
red reaper
11-28-2003 04:53:57
 Re: 715,815,915 combine diesel motor options. in reply to Sean W, 11-26-2003 20:04:59
I dont think the 361 was ever used on a combine,you must mean the 407,which was used.They look identicle except for filters.
E J
11-27-2003 19:45:52
Early 815 915 used 361cid 915 turbo charged.Most ran more rpm than their tractor counterpart motors.Most ran 2800rpm. or so.80hp too 130hp is the range on power.
Ron 1456
11-26-2003 20:49:01
The early high profile 815 and 915 had the 407 with the 915 being turbocharged. The later low profile machines used the 414 with the 915 again being turbocharged. Some of the 715 used the 301 which was just a bigger version of the 282. The later 715 used the 310 German engine. I'm not sure if any 282 engines were used in the 715.
Todd
11-27-2003 12:36:37
 Re: Re: 715,815,915 combine diesel motor options. in reply to Ron 1456, 11-26-2003 20:49:01
the 310 G diesel was about 90 hp
