1949 FARMALL M NOT STARTING
Mark
12-11-2003 05:21:12
My M was getting harder and harder to start. So I re gapped the points. Now it won't start at all. Its getting spark and its a mag. I gapped the points at .013". It seems to be getting gas. What could it be?
Thanks
Chuck's Repair
12-11-2003 15:01:49
 Re: 1949 FARMALL M NOT STARTING in reply to Mark, 12-11-2003 05:21:12
Did you turn the engine over with the rotor gear reduction removed? If you did there is a very good chance the magneto is now 180 degrees out of time.A good indicator is if it backfires through the air cleaner while you are cranking it.
doug wehner
03-28-2005 07:07:43
 Re: Re: 1949 FARMALL M NOT STARTING in reply to Chuck's Repair, 12-11-2003 15:01:49
i have a 1950 m that wont start.. i am gettingplenty of gass but when i got the car rebuilt they didnt put the screw that is next ti the govenor.. would make it not start? and would you happen to hav a plug wiring diagram?
Wayne Swenson
12-11-2003 08:13:08
For an engine to run; 1. it has to have a fresh supply of fuel in the right proportions 2. a strong spark at the right time 3. decent compression.
Which of these 3 things is missing??
If you have been cranking for a time remove the spark plugs and squirt some engine oil in each cylinder to help restore compression.
Are the spark plugs wet with gas??
Some basic troubleshootion and the "M" shuld be running in short order!
Good luck.
Mark
12-11-2003 07:35:54
Your points may have heavily oxidized and only making contact on one tiny spot. When you regapped the points you may have slightly changed the contact point to a bad area. Using gloves hold or preferably tie the coil wire about a half inch away from the block and crank engine, if you are getting a healthy blue spark, can't be a point problem. I have also seen capacitors fail and cause a no or erratic spark condition. For the price of them, when i feel points are the reason my tractor isn't running right i throw in a new set with capacitor. You should also pull the bottom off your carb and check the passages just for peace of mind.
