Farmall 200 Water Pump-?????
Pappy
12-12-2003 21:05:31
My Farmall 200 has a noisy water pump. The tractor has no serial number on it. The water pump has a round mounting plate with 5 or 6 bolts holding it to the block. I this the early or late version?? I can order a pump, but do not know the difference in the early and late pump mount.
Thanks in advance!
Stan(VA).
12-13-2003 04:22:42
 Re: Farmall 200 Water Pump-????? in reply to Pappy, 12-12-2003 21:05:31
Super C, 200, 230 should be the same pump. It uses the wide fan belt, and mounts down low on the left side with the inlet lined up with the lower radiator outlet. Several bolts hold pump to rear body, rear body bolts to block with two bolts over the long rectangular water jacket on front left of engine block. Sometimes pump is sold as a complete unit, othertimes I've seen it come as just the front section and you re-use the rear body.
New style pump would have started with 140, 240. It uses the narrow fan belt, replaces the fan pulley mount, and has a block off plate over the rectangular water jacket outlet that the old pump mounts to.
Stan(VA).
Pappy
12-14-2003 21:21:35
 Re: Re: Farmall 200 Water Pump-????? in reply to Stan(VA)., 12-13-2003 04:22:42
Thanks to Stan for the information. Looks like I have the early version.
