Covered grease zerks
Nebraska Cowman
12-15-2003 02:45:42
those covered zerks on the water pump on the Farmall M and others; why are they covered? I see McMaster Carr has replacements but they are pricey and not an exact match.
Bob MN
12-15-2003 06:15:06
 Re: Covered grease zerks in reply to Nebraska Cowman, 12-15-2003 02:45:42
nornally used in areas to keep zerk clean and where limited greasing is required.
Jon
12-15-2003 06:09:57
The covered zerk is for the water pump shaft and should be greased every 10 hours, and the uncovered zerk is for the water pump bearing and should be greased every 60 hours. Maybe the cap is there to help differentiate between the two?
Will Sick
12-15-2003 22:39:44
 Re: Re: Covered grease zerks in reply to Jon, 12-15-2003 06:09:57
The cap is on those zerks because sometimes the coolant would leak out thru them.
