H still Surges
Jake
12-16-2003 20:35:07
I cleaned the carb again with a air gun, tightend down all manifold bolts, carb bolts, adjusted the fuel and air and timing with little success. i got it to run fine w/o a load on it but when we ground feed today at high rpm she started surges like a basterd. What could be the problem. I just did a complete overhaul of the engine, rebuilt the carb, new wires, plugs, router and all the rest in that area. i would like to hear some ideas. Thanks
Chris
12-17-2003 18:15:49
 Re: H still Surges in reply to Jake, 12-16-2003 20:35:07
My H did the same thing cleaned the carb new points etc. Look in the air breather to see if it does not have some water in it mine did enough to cause it to surge. dumped of the oil and water ran fine. dont know how it got there but it did.
The Red
12-17-2003 10:24:17
Definitely replace the governor spring if it is old. Take the spring off and make sure the thruster bearing is sliding horizontally but not wiggling on the shaft. If it is wiggling on that shaft, replace that assembly. It is worn.
David in UT
12-17-2003 07:26:16
Jake,
I had a surging C this past week, and I found two problems that needed fixing: First, after repainting, the linkage arm from the governor to the carb wasn't clearing the block entirely, so it would stick when the governor threw the arm back to its max position. I had to do a little filing on the linkage arm to get it to move freely.
Second, my governor was out of adjustment. Got it adjusted and now she purrs.
Good luck,
- David
Dan
12-17-2003 06:51:19
My 53 Super H used to do the same thing under a load. It was a worn out governor spring. Local Case IH dealer ordered one for me, and it wasn't that expensive. Makes a huge difference.
Jed
12-17-2003 05:40:29
Check your intake valve settings. If they check as per spec, open them up a couple of .002.
Van
12-16-2003 21:34:38
Also if you can find nothing wrong with the carb check out the coil and condenser, seen it before, runs fine at idle and will not at power.
Van
Bob MN
12-16-2003 20:53:03
check to see if gov. shaft and carb. butterfly are engayed,check carb. filter and also tank filter and good flow at carb., if all is good try running a litle richer. good luck
rustyfarmall
12-17-2003 04:21:40
 Re: Re: H still Surges in reply to Bob MN, 12-16-2003 20:53:03
I agree with Bob, it might be time to take a look in the governor, lots of info on this in the archives.
