Order Farmall Cub Parts Online
49 cub question
JD Kid
12-28-2003 18:44:36
i need a lower radiator gasket for my cub. also have a hydrolic thing on it with a arm on each side and i cant figure out why it wont work. has oil in her and linkiges are all conected so im at a dead end. also have no oil leak from it
Phil Munson
12-29-2003 08:00:21
 Re: 49 cub question in reply to JD Kid, 12-28-2003 18:44:36
Deacon Dick Stoyell at mrih@webtv.com or 315 497 3745 has forgotten more about Cubs than anyone I know and has gobs of parts available.
Bigdog
12-28-2003 18:49:26
Radiator gasket is available from Case-IH dealers. or try Carter & Gruenewald online. The touch control system could have several issues from a bad pump, to being low on fluid. Does it whine when the engine is running?
JD Kid
12-28-2003 18:56:00
 Re: Re: 49 cub question in reply to Bigdog, 12-28-2003 18:49:26
no its quiet. when we move the levers nothin happens.it used to work when we had a belly mower on it but stoped one day so we took the mower off to see if it would work without it and nothin. thanks for the input.
Bigdog
12-28-2003 19:34:27
 Re: Re: Re: 49 cub question in reply to JD Kid, 12-28-2003 18:56:00
Pull the touch control pump @ the front left of the engine and see if the pump drive gear & nut are still there.
