IH 656 Hydro Adjustment
NeiL
12-30-2003 12:20:07
How can I keep it adjusted. Working fine, then the next time I get on it it will only go in reverse even when I put it in forward. Have to play with the adjustments. Works fine for a while, then ...
Gary
01-01-2004 06:33:28
 Re: IH 656 Hydro Adjustment in reply to NeiL, 12-30-2003 12:20:07
What part of the linkage are do you have to keep adjusting. The rod from the servo cam or the S R lever on the drive control valve. Don't know if this tractor is a Farmall or International but make sure the cowl around the SR lever is not moving also need more info on how the tractor responds when it is moving.
