how do it put on blade
richard
12-30-2003 16:27:55
does anyone know how to put on a blade that goes
in front of a 1948 farmall cub tractor. any info
appreciated
scotc
12-31-2003 16:56:25
 Re: how do it put on blade in reply to richard, 12-30-2003 16:27:55
Go to the tractor photos pages, there are some good setups there you can use as a general guideline for building a mount. One thing though, it is a good idea to brace off the rear axle, or in the case of a cub, a,or b, off the drawbar.
Farmallkid
12-30-2003 18:22:48
I don't have a cub, but my cousin does. I haven't seen a cub with a blade on it either. My cousin has a blade but it is still at grandmas farm, by the looks of it there is a bar on the back of the blade that connects under the tractor. There is a sort of backwards drawbar under the tractor for implements, Then there should be a piece of flat bar on the right side of the tractor by the axle that the blade should connect to with a chain or something. Then you can lower it with the hdy. Hope this helps.
