140 Axle Type
Kevin (FL)
01-02-2004 19:30:03
third party image
Is this an industrial 140 axle?
Harold H
01-03-2004 09:23:51
 Re: 140 Axle Type in reply to Kevin (FL), 01-02-2004 19:30:03
This axle was standard on the I-A, I-SA, F-AV, and F-SAV. The axle was optional on the regular F-A and F-SA as the heavy duty axle.
Harold H
Kevin (FL)
01-05-2004 05:59:35
 Re: Re: 140 Axle Type in reply to Harold H, 01-03-2004 09:23:51
Harold,
The tractor is a 140. Are you saying that it could have that axle as an option and that it isn't necessarily an industrial model?
Harold H
01-05-2004 14:27:42
 Re: Re: Re: 140 Axle Type in reply to Kevin (FL), 01-05-2004 05:59:35
The 140 was the same situation as the A. The heavy duty (your axle) was an option on the F-140 and standard on the I-140.
Harold H
Vern
01-02-2004 21:23:48
Not necessarilly, My '48 Super A has the same axle.
Vern
Stan(VA).
01-08-2004 06:10:44
 Re: Re: 140 Axle Type in reply to Vern, 01-02-2004 21:23:48
His question was is it the industrial axle. There are only 3 that I know of:
1- The Industrial/Heavy duty axle
2- The fixed width standard axle, and 3- The adjustable standard axle.
1 is square, 2&3 are round, so yes, it is the industrial axle.
Is it an industrial model tractor is another question.
Stan(VA).
Stan(VA).
01-02-2004 21:19:33
Yes, it's got the square cross section.
Stan(VA).
