M OIL LEVEL KNOB MISSING
mike
01-09-2004 13:31:02
my winter project this year is a 48 M with a wide frount end, lots of small things to fix and replace, the knob on the full level valve is gone. you can open it with plyers, but would like to fix it. do i need to remove the oil pan to get it out? thanks --mike
Farmallkid
01-09-2004 14:56:22
 Re: M OIL LEVEL KNOB MISSING in reply to mike , 01-09-2004 13:31:02
I bought new ones for my m the are about $8.50 can a piece
Paul in Mich
01-09-2004 14:51:34
Mike, It is not uncommon for the handles of the oil check cocks to break off. They are easily replacable, and there are sources who sell the replacements. O.E.M. comes to mind, but I'm sure there are others. The old check cock is easily removable with a pipe wrench or a pair of vice grips. They are pipe threads. Nothing should have fallen out on the inside.
mike
01-09-2004 15:08:23
 Re: Re: M OIL LEVEL KNOB MISSING in reply to Paul in Mich, 01-09-2004 14:51:34
thanks for such a quick reply, paint must be hiding the threads. got most of the tractor cleaned except the bottom.--mike
justin
01-09-2004 20:36:36
 Re: Re: Re: M OIL LEVEL KNOB MISSING in reply to mike , 01-09-2004 15:08:23
make sure you inspect the new check cock, as all of the reproductions I have seen open in the opposite direction as the originals.
