surging engine at rest in a 300 farmall
bill in orono,m
01-09-2004 18:37:08
My 300, when it finally warmed up today, surges when it is at and above idle up to 1/4 or 1/3 throttle.
Would this be a gov. spring, linkage, ghosts or what?
Thanks,
Farmall Newbie Bill
ChadS
01-09-2004 21:23:14
 Re: surging engine at rest in a 300 farmall in reply to bill in orono,mn, 01-09-2004 18:37:08
It could be the governor spring, worn governor weight pins. if it is extremly cold where you are from, may have some ice or very cold engine oil still in the governor, also in the governor shaft to the carb itself. You might check the idle adjustment as well. Check for any vacumm leaks on the carb/manifold flange. Hope this helps,, chad
