Farmall 350 broken boss on engine block
Andy
01-13-2004 07:16:21
I have a Farmall 350 and I have been working on installing an external coolant heater to it. I started by trying to remove the drain plug located behind the carburetor. My particular set up had a brass 45 degree street elbow coming out of the engine block and a steel plug in the end of the elbow. In the process of removing the plug from the brass elbow I broke the brass elbow off at the engine block, leaving about a ½” of threads inside the block.
I found an Easy Out that would fit the ID on the broken fitting and attempted to use it to remove it. My problem is that it just kept going in until the circular boss that holds the fitting cracked. Now, I’m not sure what to do.
First off all, what did I do wrong with the Easy Out? It sure wasn’t that easy.
Secondly, and more importantly, what can I do now to fix my predicament?
As always, thanks in advance,
Andy
Aces
01-13-2004 14:46:54
 Re: Farmall 350 broken boss on engine block in reply to Andy, 01-13-2004 07:16:21
Andy What did you do wrong with EZout, you used it most are to look at. I have a set and a person can still some like them. They are very short with a sholder to stop them from going in as yours did and they have a 9/16 hex head. If I can't make these work I start digging.
Bill Ramsey
01-13-2004 07:34:11
Andy I would take a hack saw blade and cut until you reach th threads in2 or 3 places and use a sharp pointed punch and pick out the pieces.Then grind a V in the crack and patch with JB Weld should keep it from leaking. LOL. Bill
