454-d Smoking
HomerBinNC
01-20-2004 05:29:44
This weekend I looked at a 454D with W/ loader. It looks good except it has a lot of white smoke. When I pulled the kill switch out slow the engine speed increased just before it died. Anybody have any idea what’s wrong? He is asking $6900, should I keep looking? Thanks for your help.
clanger
01-20-2004 15:17:03
 Re: 454-d Smoking in reply to HomerBinNC, 01-20-2004 05:29:44
If you have white smoke/fumes coming from the crankcase breather you may need to replace the sleeves & pistons. My 484 is getting these this weekend - hopefully it will do the trick.
Dave
01-20-2004 10:47:33
Quite a bit of white smoke from a 454D (or any older diesel) is common at start up. You will probably also see some white or grey smoke even after running a while. That is normal according to the IH manual. To be 100% sure, you really need to see what it does under a load when fully warmed. My 454D has a recent rebuild on the engine and still makes a little smoke, even after warming up. When running under a load, either loader work or bush hogging, there is not a trace of smoke. I probably need to ckeck my thermostat.
As far as cost, $6800 is a good price for a 454D and loader in good condition here in PA, but prices always seem a little high here.
