450 IH Standard HELP!!!
GEA
01-25-2004 17:44:58
Have nice non rinning W-450..Winched it up on my trailer NOW it will not roll.Even with Clutch in...Seemd to be stuck in gear BUT even depressing clutch will not release the tractor, is there a way to check or What ever the Clutch??
Bob M
01-26-2004 04:52:06
 Re: 450 IH Standard HELP!!! in reply to GEA, 01-25-2004 17:44:58
Most likely the tranny got caught in two gears at once. It's a common problem with these tractors when the bottom end of the shift lever gets worn.
To correct, first remove the shift lever (knock out the pivot pin in the tranny cover at the base of the shift lever, then lift lever out). Now look inside at the slots on the 3 shifter rails. For the tranny to be in neutral the slots in all 3 rails must be centered in the opening. If not, take a LARGE screwdriver or similar prying tool and move the rails to the center as needed. (You may need to jack up one rear wheel to release the load on the gears in order for the rails to move.) Finally replace the shift lever and retaining pin.
A permanent fix involves building up the worn "button" on the bottom of the shift lever.
Good luck!
GEA
01-26-2004 18:24:09
 Re: Re: 450 IH Standard HELP!!! in reply to Bob M, 01-26-2004 04:52:06
Do you think clutch is stuck also?? Even pushing clutch in will not let tractor Roll..THANKS
Donnie
01-25-2004 21:53:08
I put the picture on the tractor photo page. Its under W-450 and W-400. Tried but was not smart enough to put them on this page. Thanks.
williamf
01-26-2004 05:23:00
 Re: Re: 450 IH Standard HELP!!! in reply to Donnie, 01-25-2004 21:53:08
third party image
If you have a picture on Tractor Photos ( or any where else on the web, except that some of the free or low cost photo posting services, maybe Epsom for instance won't let you) it's easy to get them on a post. Just go to the picture and right click on it. On the pop-up menu that comes up click on "Properties." Then select the Address(url), in this case
Link
by dragging the curser over exactly those words.
Then right click on what you've highlighted and click on "Copy."
Now come back to Post a Message and write your message. Then move the curser to the box by "Optional Image URL," right click, and click on "Paste."
Your photo will now show up when you post.
Wm
Donnie
01-25-2004 21:13:34
Are going to restore the W-450? If so I would like to share a couple of pictures of Dads W-450 and W-400 that we just got done with. I could try to send them over this but, never done that before. These tractors are very neat when they are restored. Not many of them around at the shows.
Ross
01-25-2004 20:08:59
I had an Oliver that would not roll, brakes discs were rusted to outer brake housing
Red Rider
01-25-2004 19:15:53
Is the transmission in neutral? If the trans is in any forward gear and the TA is forward It won't roll backwards. The planateries in the TA do not like turning backwards with reverse torque. Try pulling the TA back and see if it will roll back off your trailer.
42FarmallH
01-25-2004 18:16:03
Is the temperature below freezing there? If so I would assume there is water in the transmission/rearend sticking the gears.
GEA
01-25-2004 19:42:19
 Re: Re: 450 IH Standard HELP!!! in reply to 42FarmallH, 01-25-2004 18:16:03
Transmission does appear to be stuck..Not freezing here Could the clutch be STUCK?? If so is there a way to get it Loose??
