F-20 Flywheel
John in NE
01-27-2004 03:56:13
I got the darn thing off,now how do I get it back on? Any clues would be helpful. John
Mike
01-27-2004 20:54:51
 Re: F-20 Flywheel in reply to John in NE, 01-27-2004 03:56:13
Tap rear of crank (where felt it) get a piece of threaded rod and a thick piece of stock with a hole in it and put a nut on it and just thread it on. Then plug hole in crank and use a sealed bearing for the pilot.
dlp
01-27-2004 18:13:34
If you beat it on, remember that the main ball bearings are taking the shock. I haven't installed the flywheel on my engine yet, but "driving" it on doesn't sound like an option. I do know that if it is heated it will go on easier.
F-man
01-27-2004 16:10:41
You need to clean the crank and flywheel surfaces and use some WD-40 to help the flywheel on. You don't have to beat very hard. Just take a block of wood and bump it back on. You need to check for run out with a dial indicator. It should not exceed .006". This is very important to ensure proper clutch operation.
Nebraska Cowman
01-27-2004 05:23:25
do you want to borrow my driver? It takes a heavy sledge hammer!
John in Ne.
01-27-2004 13:07:04
 Re: Re: F-20 Flywheel in reply to Nebraska Cowman, 01-27-2004 05:23:25
Are you saying that I have to beat it back on? It came off hard, but I was hoping there was a way to "wish" it back on.John.
Nebraska Cowman
01-27-2004 15:40:40
 Re: Re: Re: F-20 Flywheel in reply to John in Ne., 01-27-2004 13:07:04
you wish! I guess you could chain it to a tree and use a hydaulic jack to press it on. But no, John, the word is DRIVE it on, not BEAT. Use controled blows and the right size hammer.
John in NE
01-27-2004 21:32:34
 Re: Re: Re: Re: F-20 Flywheel in reply to Nebraska Cowman, 01-27-2004 15:40:40
Thanks for all of the help. I hope it warms up this weekend so I can get back to work on it. John.
