10' Wheel Disk to much for '46 H?
Jim
01-31-2004 08:55:48
Looking for a disk for my H and saw an upcoming auction that has an IHC 10' wheel disk going up for sale.
Wondering if this would be too much of a disk for my H, at the limit of its capability, or should do fine.
Soil where I will be using it has good amount of clay, rolling hillside with some small rock.
Thanks for your advice, Jim
Irv
02-01-2004 14:01:38
 Re: 10' Wheel Disk to much for '46 H? in reply to Jim, 01-31-2004 08:55:48
I use a 300u to pull a 10 ft tamdem disk- it is worn, but it was a real load for my 300. Irv
Chris Brown
01-31-2004 17:10:40
My old H pulls my IH # 37, 9 and a half foot disk with no weight on the boxes and the angle about half way. It is short on power and weight but it has pulled it many hours,I have to pull in 1st and 2nd gear. An 8 Footer would be perfect.
Hugh MacKay
01-31-2004 14:33:58
Jim: There must be a lot of worn out disks across North America. A good wheel controlled disk with 18" notched disk blades will require 1 hp per blade. You will get by with slightly less hp on 16" blades. 18 and 20 inch blades worn down to 16 inch arent worth a tinkers damn.
If an H or a 240 is pulling a 10' or more tandem disk, the disk is not much good. In fact I suggest a land roller would do as well.
MT Pockets
01-31-2004 17:14:58
 Re: Re: 10' Wheel Disk to much for '46 H? in reply to Hugh MacKay, 01-31-2004 14:33:58
I can tell you with authority that Hugh is right about this.I pulled a 5 foot disc many many days with a 1947 H in late 50's and early 60's in north Ms. If you were cutting stalks before breaking the ground, you might use 4th gear because the disc wouldn't go very deep. But after you broke it 6 or 7 inches deep, and dirt was running over the disc axles, it was 3rd gear at best. Steve Norwood, Texarkana.
It depends
01-31-2004 13:38:12
Width of disk is just one factor in determining what you can pull. Just as important is diameter and pitch of disk blades, scalloped vs smooth disks, weight on disk and angle of cut. I do not doubt that H will pull 10 ft. under some conditions but where I live H is not going to pull 10 ft. with new scalloped disks with all angle in that is in plowed ground and cutting. They only pull 18 ft. with 150 HP tractors with duals.
riverbend
01-31-2004 12:01:35
Neighbor's 11 foot wheel disk was all my worn, distillate H wanted in 1st gear. I want to try it again after rebuilding the motor.
Doug in OR
01-31-2004 11:23:35
Are you referring to what we called a "tandem disk" when I was growing up? A 10 foot tandem, in soft soil, will be a bit much for an H. In clay or other hard soils where you do not get much penetration, you shouldn't have any problems. A 10 foot single disk shouldn't be any problem, no matter what the soil type.
JD5020 guy
01-31-2004 11:38:12
 Re: Re: 10' Wheel Disk to much for '46 H? in reply to Doug in OR, 01-31-2004 11:23:35
Good point. But the disk I pulled was a tandam disk.
JD 5020 guy
01-31-2004 11:09:46
Pulled a 10ft IH disk with a 240 Utility which is 28 hp. I went as deep as it could go and I was in 2nd gear. The disk was the kind where you have to remove pin, drive forward, and put the pin back in.
42FarmallH
01-31-2004 09:50:48
I pull a 12 foot disc with my H. It doesn't have wheels, it's the one that just rides on the ground. It will pull it fine in 2nd gear as deep as you want. 3rd gear you can't go quite as deep, but it still pulls it OK.
I have the low compression distillate engine too...
ryan
01-31-2004 09:11:09
pulled a 10' wheel disk with a 300 second gear most of the time and it's 40 horse
John
01-31-2004 18:54:24
 Re: Re: 10' Wheel Disk to much for '46 H? in reply to ryan, 01-31-2004 09:11:09
I pull a 10 1/2 ft. wheel disc with my 46'M and its a load when its disking plowed ground. if i were u i would look for a slightly smaller disc,u don't want to over work the old girl...
