Will w-30 engine fit t-20 crawler?
J.R.
02-02-2004 15:39:46
Ihave a w30 mccormick engine and wondering if the clutch and bellhousing would fit a T-20 Crawler with a bad engine. any advice is highly appreceated. thanks
Mike Androvich
02-03-2004 14:49:39
 Re: Will w-30 engine fit t-20 crawler? in reply to J.R., 02-02-2004 15:39:46
J.R., A W-30 engine will not fit in a T-20. The T-20 used an engine very similar to a F-20, except the crawler engine had a fuel pump and a water pump. Many T-20s have been converted over the years, but I can say with certainty that a W-30 engine is not the same. I have three T-20s myself. The block in the crawler does not use the tractor bell housing, but mounts with an adapter plate right to the frame. Will not work!!!
Big Don
02-03-2004 12:52:38
I'm not an expert on this BUT, I am almost certain that the T-20 used the same motor as an F-20 which is smaller than the 10-20 or W-30 motor size. I saw a T-20 one time that had a 10-20 motor mounted in it (or so I was told) and the motor was longer than the frame. It stuck out the front several inches.
Don
F-Dean
02-02-2004 20:19:51
I believe the crawler has a 10-20 engine which is the same as a W-30 engine without a water pump. Depending on the problems with the T-20 engine, you may be able to use the W-30 block and head without the water pump. Compare the head gaskets carefully to determine the differences.
Martin Caldwell
02-03-2004 09:45:56
 Re: Re: Will w-30 engine fit t-20 crawler? in reply to F-Dean, 02-02-2004 20:19:51
I have always read and thought that a F20 motor is simlar to the motor in a T20. All T20's I have seen sure look like a F20. If I am wrong I will accept it as being missinformed.
