Farmall H clutch replacement question
Dick in Fallon
02-12-2004 13:02:01
The four bolts holding the clutch shaft to the tranny will not turn and I am reluctant to try pounding them out. The nuts came off easily but the bolts are super tight, any ideas would be very welcome, and thanks.
Dick in Fallon
03-04-2004 13:36:22
 Re: Farmall H clutch replacement question in reply to Dick in Fallon, 02-12-2004 13:02:01
Now that I have the clutch on my"H" ready to replace, can anyone tell me what kind if puller I can find to pull the pilot bearing in the flywheel. Thanks,Dick
RayA
02-12-2004 18:52:23
I took these bolts out last summer to change a shaft seal. I think I invented a few new words by the time I got them out. I had to use a crowbar and a hand sledge. Persistence was what paid off for me in the end. If you go to replace these bolts be prepared to spend some money. I dont remember exactly how much they cost, but remember they weren't cheap. Good luck. RayA
Dick in Fallon
02-12-2004 19:09:17
 Re: Re: Farmall H clutch replacement question in reply to RayA, 02-12-2004 18:52:23
Hi RayA, thanks for the help, I feel like I will get some results with all the help from you"Experts".LOL, thanks again for the return,Dick
RayA
02-12-2004 19:29:01
 Re: Re: Re: Farmall H clutch replacement question in reply to Dick in Fallon, 02-12-2004 19:09:17
I am hardly and expert like some of these guys,,I think the painful memory of the ordeal is still burned in my mind..lol. Have heard some say theirs came out w/o much fuss. Mine was not one of those stories. RAyA
Wayne Swenson
02-12-2004 17:49:12
Just removed the ones on my son's "H".
Use a large pipewrench to keep the clutch shaft from turning by gripping the "ears" of the shaft, not the shaft itself and let your wrench force the pipewrench against the housing. Now you have both hands available to attempt to turn the bolts with a long handled wrench or socket & breaker bar; once they break loose then they fall out. I have had to resort to heating the "ear" so the tapered bolt would let go on some other tractors.
Good luck.
Dick in Fallon
02-12-2004 19:06:18
 Re: Re: Farmall H clutch replacement question in reply to Wayne Swenson, 02-12-2004 17:49:12
Wane, thanks for the advice, too cold right now to go try, but will give it a shot in the morning,thanks again, Dick
riverbend
02-12-2004 13:57:20
The bolts have a taper and hold on really tight. I turned the nuts back on a few threads short of snug and pushed them back with a crow bar.
