Gen Problem
Red Tom
02-14-2004 11:25:38
I was here before but still need help. Have a340 new 6volt batt, good gen, new reg, was charging but after sitting along time now won't charge. How do I polarize the gen? I used to close the contact in the reg by hand and it would be ok but now when I did that it went discharg instead. any advice? Thanks
Chris in SeMo
02-14-2004 14:45:23
 Re: Gen Problem in reply to Red Tom, 02-14-2004 11:25:38
Red,To polarize the generator you need to momentarily touch a wire to the BAT and GEN terminals on the regulator,BEFORE you start the engine. You should get just a quick spark.Hope this helps,Chris in SeMo.
