super A gas tank
mikeinWA
02-20-2004 01:12:53
Just got in from work and found my new/old gas tank for the super A. Opened the box and was dissapointed to notice that the mounting brackets on the tank are different from those on the old dented tank I intended to replace. Original tank had two brackets on the underside which fit outside the hydraulic resevoir then tappered toward the front of the tractor and fit outside a bracket mounted directly to the back of the engine. New tank has two small brackets at the rear which will fit the threaded holes in the resevoir, but nothing up front to accomadate the bracket at back of engine. New tank also has holes at front in the ridge created by the seam of the tank where the old tank had two plates to catch the "J" latches. The question is "why me?". No really, the question is what is this new tank from and can I make it fit, or rather has anyone out there made one fit. The supplier has been great in the past and I was very surprised to find this difference. Its too late to call but I will speak to the supplier in the morning. Any help or shared experience is greatly appreciated.
Stan(VA).
02-20-2004 04:45:50
 Re: super A gas tank in reply to mikeinWA, 02-20-2004 01:12:53
You might have a real late model tank. The gas tank on the 130/230 had a seperate bracket that bolted to the front, and optional extension brackets on the rear to fit the Super C/200 ... tractors that sat up a little higher.
Stan(VA).
scotty
02-20-2004 03:42:24
Mike, Sorry to here of your incorrect order! I would call your supplier and tell him of the difference. As long as the two bottom ribs on the gas tank have the proper foward holes you should still be able to mount that foward L bracket to the bottom of the tank and bolt it to rear of engine. So see if your supplier can get you the proper bracket!
scotty
mikeinWA
02-20-2004 11:57:30
 Re: Re: super A gas tank in reply to scotty, 02-20-2004 03:42:24
Scotty-New tank doesnt have these forward brackets, it only has two holes in the rib where the top and bottom of the tank are joined, it also lacks strike plates for the latches of the hood..I think I just saw some pics of your SA on the photos section, inspired me to add afew of my own, looks like we are in the same boat.
