insterment switches on 100
jeeper
02-23-2004 19:09:26
on my dash there are a volt gauge, start kill buttonand a round 3 postion knob. what is the round knob for. iwould guess for lights but it dose not have any and it dose not likeit ever did jeeper
Hugh MacKay
02-24-2004 03:34:57
 Re: insterment switches on 100 in reply to jeeper, 02-23-2004 19:09:26
Jeeper: All 100's would have had lights from factory, the round one is indeed your light switch. If you look on front of tractor, right light mounted on top of steering box by the use of a stem into a hole in casting and held by a set screw. You will find a matching hole on left side for the left light. The rear light on these was usually mounted on a bracket coming from left seat support to rear of tractor. If you have an operators manual for tractor there is an excellent wiring diagram in the manual. The wires for the front lights should be in the harness going to the generator or alternator, which ever tractor has.
jeeper
02-24-2004 18:41:00
 Re: Re: insterment switches on 100 in reply to Hugh MacKay, 02-24-2004 03:34:57
guess i have alot to learn about farmalls , my old 9n ford seems to be simpler to work on. i may be in need of a good manual. thanks alot for all the help. jeeper
Hugh MacKay
02-25-2004 01:35:32
 Re: Re: Re: insterment switches on 100 in reply to jeeper, 02-24-2004 18:41:00
Jeeper: It's all about being familiar with a certain product. We bought a Cockshutt on the farm once, and after years of Farmalls that was a hard one to get used to.
TDK
02-23-2004 20:03:31
Your right,,,,,it's the light switch.
