444 gas tractor transmission
Jim
02-26-2004 06:22:42
Just purchased a 1970 model 444. high range in transmission won't engage. Any Experiences with such?
JB
02-26-2004 18:44:46
 Re: 444 gas tractor transmission in reply to Jim, 02-26-2004 06:22:42
I am with BlueLite, it is a simple but rugged transmission. I pulled the top off of a 434D that we owned back in the 70's and it was not a difficult job. I believe I had to disconnect hydraulic lines and remove some bolts and it lifted straigt up and off. Ours would jump out of 2nd gear going down a hill with a heavy load behind it. The problem was worn indents in shifter rail.
Good luck
JB
BlueLite
02-26-2004 06:34:07
Sounds like a prob in the lever component or shift rails. Pull the trans cover and have a look.
It takes a lot to damage the transmission so it's pretty certain it's in the rail or shift system. A set screw or something simple probably came loose.
