Hydraulic help on H
Kenneth
02-28-2004 18:13:00
I bought a live hydraulic pump for my H off of a 300 farmall and was told it would work, but have come to find out that only late 50 models on up will it interchange with. Now I am left with hydraulic pump that won't work, and a gutted belly pump can anyone tell me where I can find a live hydraulic pump that will mount between the distributor on a 49 model H. I have found some but they are for latter series H,s and super H,s does anyone know where I can find one for older models
jed
03-01-2004 05:27:26
 Re: Hydraulic help on H in reply to Kenneth, 02-28-2004 18:13:00
Change the cam gear if you change the front covers.
If you don't change it now you will have to change it shortly after you install the live pump. The H gear is soft and it will break running continually against the live pump gear.
CNKS
03-07-2009 08:27:19
 Re: Still Working On Brush On Color for A WithOUT Hardener in reply to Tom in Iowa City, 03-07-2009 07:07:12
2150 and 50 can be custom mixed by PPG/DuPont, etc. The PPG/Dupont codes for IH 50 are 70019/7410. For 2150 they are 71310/96766, Can be crossed to any major paint manufacturer. IH 50 cannot be bought from Case IH, nor can the other two reds from that era, IH 1102B and IH 201. The acrylic enamel mixed as IH 50 may or may not be higher quality than the 2150 CaseIH sells, it will be more expensive and a different shade.
Krazy-Ken
03-07-2009 08:22:54
 Trojan Grader in reply to Tom in Iowa City, 03-07-2009 07:07:12
wh
02-29-2004 06:38:56
if you can get the front engine cover for the 300 the pump came from yours should work.
