Auxillary Hydraulics for Super C
SuperCmore
03-01-2004 11:26:21
Is there any way to put a one way or even two way auxillary hydraulics on my Super C?? it has Fast Hitch, and I don't want to unhook the cylinder from the Fast Hitch to do it. Thanks, Cmore
CNKS
03-01-2004 18:21:46
 Re: Auxillary Hydraulics for Super C in reply to SuperCmore, 03-01-2004 11:26:21
If you have an operator's manual, there will be a diagram for this. You can use that as a guide and rig your own.
Randy in NE
03-01-2004 12:17:02
I'm not sure how your Fast Hitch is plumbed but I would think that you should be able to tap in somehow and make it work. The two way cylinder is not a problem in that you are returning just as much oil on the back side of the piston as you are applying to the front side. A one-way cylinder requires a sump of some kind. I put a 2.5 gallon tank on the side of the torque tube on the right hand side. I can raise the hoist on an old farm wagon with no problem. It is just a little slow. I tapped into the hydraulic lines right where they into/out of the touch control unit and it only has about an 1/8" port for the oil to pass through.
SuperCmore
03-01-2004 12:37:56
 Re: Re: Auxillary Hydraulics for Super C in reply to Randy in NE, 03-01-2004 12:17:02
Could I just plumb into my hydraulic lines right at the Fast Hitch cylinder in the back of tractor? That would be neat if it would work....then put the "female" hydraulic couplers on and I'm set, right?? Cmore
potosi
03-03-2004 14:33:44
 Re: Re: Re: Auxillary Hydraulics for Super C in reply to SuperCmore, 03-01-2004 12:37:56
No you cannot just tap in to the lines at the cyl,if you did every time you used your lift both systems would operate at the same time.There is a adpt. plate that goes between the hyd. manifold and the hyd. res. Also I think you can tap into the hyd. oil pressure check port on the hyd. manifold for your pressure, then the return oil into the system elswhere. Hope this helps.Lynn
