Farmall H belly pump seal
Jeff
03-03-2004 20:36:45
How do you get the seal off the fitting that has three bolts holding it to the tractor. It is then connected to the belly pump by the rod you slide up and connect????? Help????? Thanks
Theman
03-04-2004 10:55:42
 Re: Farmall H belly pump seal in reply to Jeff, 03-03-2004 20:36:45
Jeff, the slotted end of the shaft is actually a threaded stub. It can be removed either with a pipe wrench on the OD or piece of key stock/pry bar in the slot and a whack with a hammer. It has standard threads and will unscrew right out of the end of the transmission countershaft. Next, remove the 3-bolt seal housing. Carefully replace the seal in the housing and reassemble. Don't worry about getting the stub too tight. The load from driving the pump tightens it back up.
26Red
03-04-2004 09:40:18
Do you have the belley pump out of the tractor? Or are you referring to the lower shaft seal that goes into the transmission case?
